It is currently Fri Jul 18, 2025 10:13 pm
PostPosted: Mon Nov 13, 2006 4:39 am
Related to Hesh's problem with the binding cutter I am considering a
vacuum holder.
A few questions for those who use them
I see LMI sells a holder that looks very nice but expensive.
Anyone have this one?
Also, do they hold an unfinished not so smooth guitar well????
TIA
PostPosted: Mon Nov 13, 2006 5:44 am
I think Lance has one...
PostPosted: Mon Nov 13, 2006 6:04 am
Also, If you build a box for braces, how do you hold you braces so the they
don't shift when applying the vac.
PostPosted: Mon Nov 13, 2006 6:10 am
I have one, I couldn't build without it. But that's likely because I've never had to. It was one of the first tools I bought specific to guitar building. If you'd like, I can donate one to the AndyZimmerman guitar cause. I've got one made of UHMW that I've never used. It might need a bit of work to make it fit your needs but it's a good starting place. Email me with your address and I'll get it right out. paul at woolsonsoundcraft dot com.
On the vacuum box question: I hold them down with a small strip of masking tape at the ends of the brace. When I hear the "POP" of the tape breaking, I know I'm getting close to full vacuum.
I have a Vacupres pump and use it with a vacum clamp.
Mine is fashioned after the LMII model. I made is from 3/4" plywood and consists of a base that clamps to the work bench edge. A vertical circular plywood disc is attached to the base and
Over hangs the edge of the bench. The circular disc is about the diameter of the width of the waist smallest of the guitars you hold and has a hole in the center to match the hose from the vacum pump. A circular ring of vacum gasket runs parallel to the edge of the disc about 1" from the edge.
Be very careful to place the vacum plug-in and/or the switch where you will not accidentally disconnect the vacum. From experience!
Many woods will require a seal coat. I use a wash coat of shellac or too much air penetrates the wood and weakens the vacum.
I have found the system to work well and is extremely useful.
Hope this helps.
I have it ... it is great.
PostPosted: Mon Nov 13, 2006 6:23 am
I simply hold the braces in place with right angle strips of masking tape and place the whole piece into a concave disc to match the desired plate radius.
Apply the vacum and then release the vacum after 10 minutes. Remove the masking tape, and the droplets of partically dried glues along the brace and the soundboard/back with a plastic scraper. Then reapply the vacum until the require time for the glue to firmly set.
PostPosted: Mon Nov 13, 2006 6:27 am
Thanks all
Wow Paul....what an offer!!!!
PostPosted: Mon Nov 13, 2006 7:04 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Anybody use this method with HHG? If so are there any issues related to speed? I'm just thinking of how fast HHG gels, and trying to get the braces taped, then starting the vacuum...
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Mon Nov 13, 2006 7:24 am
Mark, I don't use HHG very often, simply because I'm not confident with my speed. Throw in a vacuum setup and I'm sure I wouldn't be fast enough to pull that off.
PostPosted: Mon Nov 13, 2006 8:51 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Paul: <grin>
Yeah that was my thinking too. I've just started using HHG on my bracing - I'm fast enough for that with go-bars, but there is no way I'm fast enough for a top/back glue up! So I'm sure I wouldn't be fast enough for braces using vacuum.
-Mark
Mark Tripp39034.8383680556
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Mon Nov 13, 2006 9:44 am
Anyone have any experience with this vacuum pump?
I'm primarily interested in using it for clamping bridges and maybe some router hold down applications.
John How39034.7399768519
PostPosted: Mon Nov 13, 2006 12:44 pm
if you are going to use vacuum i would suggest you build a reservoir system along the lines of that described on joewoodworker's site. with a reservoir the clamping is instantaneous when the valve is opened and the time issues referred to above are not relevant.
i used to use a vacuum pump for a number of clamping/holding operations, particularly for routing, but eventually switched to using a venturi and built the reservoir.
PostPosted: Tue Nov 14, 2006 12:42 am
Paul,
Can you share a few pics and comments of your vac clamp before you ship it out?
PostPosted: Tue Nov 14, 2006 1:26 pm
First name: Dean
Last Name: Bayles
City: Leucadia
For those of you that would like an LMI type vise at a very resonable cost and an easier, smoother action, get yourself a PanaVise 300 and add a clamped on vacuum disk. Available on ebay right now from $10 to $34. Check out the vises at Panavise.com
Dean
Dean
PostPosted: Tue Nov 14, 2006 1:52 pm
I have one and LOVE it. I don't use it as much as I could but only because of the way I am set up. Hopefully ( if I get my new shop...hopefully) I will have a seperate area for it's exclusive use. It is a great device...worth every penny.
PostPosted: Wed Nov 15, 2006 6:57 am
[QUOTE=Dean] For those of you that would like an LMI type vise at a very resonable cost and an easier, smoother action, get yourself a PanaVise 300 and add a clamped on vacuum disk. Available on ebay right now from $10 to $34. Check out the vises at Panavise.com
Dean[/QUOTE]
You know, that's a pretty darn good idea there. Thanks for the tip.
PostPosted: Wed Nov 15, 2006 7:23 am
Perhaps if someone would give us a line on a vacuum disk? That would be terrific!
Edit:
Google or Dogpile on "Vacuum Cups".Don Williams39036.6494560185
Users browsing this forum: Bing [Bot] and 13 guests
